stadin
Aug 03, 2023Aspirant
Ready NAS ultra RN 10400 disk fail
Hi I hade a disk fail in my setup but now i cant access anything. Not sure if removing and adding a new disk will help. The broken disk is not showing in the menu. Any suggestions are appreciated ...
Aug 03, 2023Guru - Experienced User
Start by downloading the full log zip file from the logs page.
Was there a power interruption of some kind?
stadin
I rebooted a couple of times. But it started with error message degraded data. I have the zip file. Do you want to have a look?
- StephenBAug 03, 2023Guru - Experienced User
Sure. Upload it to cloud storage (google drive, dropbox, etc), and get a link that is set up so anyone with the link can download. The send me the link via private message (PM), using the envelope icon in the upper right of the forum page.
You'd see that if one disk fails. But the inactive volume suggests that something else also went wrong.
