haywardsteve
Apr 03, 2019Aspirant
ready NAS21400 playing up after firmware update
after the update to the firmware was upoloaded the drine seems to be playing up as I cannot access any of the files stored on there (over 4TB of data) the drive activity led is flashing all the time ...
- Apr 11, 2019
I have found the firmware update turned " ON " both the anti virus and indexing feature of the NAS and it was in the middle of scanning the drives, But it takes days to scan and index 7 Tbyte of files so when it finished things returned to normal.
WHY ARE WE OPTED INTO SOMETHING WITHOUT BEING INFORMED ABOUT IT
haywardsteve
Apr 04, 2019Aspirant
Yes I can read the folder tree but it Takes ages to show the folder tree BUT i cannot move files between tiers of the tree IE between folders and sub folders.
I want to clean up the files by creating sub folders to move the files into BUT the NAS just sits there not doing anything Some times I get a not responding error on file explorer.
All this time the drive has a green led flashing ( the righthand one showing drive access) this is after 2 days,This led does not go out even after the computers all all switched off.
The two NAS units (two NAS units with 4 2TB drives with and permanet IP address's) hold my film,video and music files which I have collected over the years and I do not want to lose this data. Before the firmware update they were working fine (or so it seems) but slowly and now after the update and updateing Raidator the problem started and I have no clue in how to fix this so I would like a simple way to fix in a way I can understand without having to lose all of my data.
WHY DO COMPUTER MANAFACTORS ALWAYS MUCK UP OTHER PEOPLES SYSTEM WITH THEIR UPDATES, I AM ALWAYS HAVING TO RESET UP MY MACHINES BECAUSE MICROSOFT DOES NOT LIKE SOMETHING THAT I USE LIKE HOME GROUPS BEING REMOVED WITHOUT ANYTHING REPLACING IT TO FORCE YOU TO USE THEIR CLOUD SYSTEM ( I DO NOT TRUST CLOUD SERVERS BEING SECURE TO LEAKAGE 0
Apr 04, 2019Guru - Experienced User
Have you looked in the admin web UI to see if the NAS is doing anything unusual? Or instance, resyncing the volume, or perhaps running a volume scrub or a balance? These should show up in the log page, and perhaps also as notifications on the volume page.
Also,
- What firmware are you running (please give the version, not "latest")?
- how full is the data volume on the two ReadyNAS?
- How are you trying to move the files - Windows explorer? Or some other way?
One aspect here - if you want to keep your data safe, you need to have backups (at least one copy on another device). Are you doing that? For example, is your second NAS a backup NAS, or is it just additional storage?
- haywardsteveApr 11, 2019Aspirant
