_The_Blockhead_'s avatar
Jul 24, 2019
Readycloud is not discovering my NAS and RAIDar sends me to a very old version of the admin page
Recently I bought this NAS second handed without the drives. I did a factory reset to start of clean, but now I have issues with setting it up. I watched the tutorial form Netgear, but I got stuck at...
  • Marc_V's avatar
    Jul 24, 2019
    @_The_Blockhead_
    Welcome to the Community!
    You have the ReadyNAS Duo V1 which runs on ReadyNAS RAIDiator 4.1, unfortunately ReadyCloud will not be able to get this NAS setup since it is available only for OS 6 devices. Downloading RAIDar like what you did is one of the first steps to setup this NAS. Here is a link to it's hardware manual to get you started on using your ReadyNAS Duo V1 Smiley Happy
    you will have to start RAIDar and select your NAS to start the setup Wizard and after completing that you should be able to get your NAS going. The manual will have the steps provided and other info you might need is also available there
    The Video you have seen might be for the OS 6 version that is why you are seeing a different UI and setup procedure. This video from another user might help https://www.youtube.com/watch?v=ijiczeaQnrI and https://www.youtube.com/watch?v=pVY1jmgsM2g
    HTH
    Regards
ProSupport for Business
