seagull3's avatar
seagull3
ReadyCLOUD - No Device Discovered (RN212 ReadyNAS)
Hi,
After it ran fine for about a year, my ReadyNAS212 acted up and I had to factory reset and reinstall OS.
Now, ReadyCLOUD can not discover my device eventhough RAIDar see it. Please see the attached file.
Could you please tell me what to do.
Thanks,
Seagull3
  • Hi seagull3,
    You can try disabling and re-enabling the ReadyCLOUD service on NAS. You can also try logging out and logging back into the ReadyCLOUD desktop app and see if that helps.
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi seagull3,
    Welcome to the Community!
    Have you checked if the ReadyCLOUD service is enabled on the NAS? Since you did a factory reset, this service will be set to OFF by default.
    You may check this by logging to the NAS admin page, then go to Cloud tab.
    Once it is enabled, you should see on that page that the Internet and Service have green check marks
    • seagull3's avatar
      seagull3
      Sorry for being ignorance. How do I enable the service on the NAS? Attached is the screencapture of my ReadyCLOUD. I can not go to the NAS admin page.
      Thanks
      Seagull3
      • StephenB's avatar
        seagull3 wrote:
         ... I can not go to the NAS admin page.
        Well, that is exactly what you do need to do.  Have you tried https://nas-ip-address/admin ?  Once you are in the admin web ui, you go to the cloud page and enable ReadyCloud.
ProSupport for Business
