Geoff-S
Sep 24, 2016Aspirant
Can't discover my ReadyNAS-104
I can't discover this device on ReadyCloud. I did have it set up at one time, and it stopped show up, so I removed it from ReadyCloud so I could try re-adding it. It is on firmware 6.5.1 and shows up just fine on my network and can be found with the RAIDar tool and through the admin page of the NAS itself. It reports itself as healthy. Any help would be greatly appreciated as I cannot current access this device remotely through ReadyCloud.
Thanks!
If internet connectivity is working you should have seen that update.
If you set a static I.P. address check that the DNS server addresses are specified correctly.
- mdgm-ntgrNETGEAR Employee Retired
Please update to 6.5.2 and send in your logs (see the Sending Logs link in my sig).
Is the NAS showing up in RAIDar and in the web admin UI with the correct 13 digit Serial Number that is printed on a label of the unit?
If you are trying to join it to ReadyCLOUD are you remembering to use your MyNETGEAR account?
- Geoff-SAspirant
Hi.... I don't see 6.5.2 on the firmware download page linked in your footer.. just 6.5.1, and when I click on Check for updates on the admin page, it doesn't do anything. Do you have a direct link?
Yes the NAS shows up in both RAIDar and the web ui with the correct serial number.
I am a member of ReadyCloud and was able to access this NAS previously.
