Geoff-S
Sep 24, 2016Aspirant
Can't discover my ReadyNAS-104
I can't discover this device on ReadyCloud. I did have it set up at one time, and it stopped show up, so I removed it from ReadyCloud so I could try re-adding it. It is on firmware 6.5.1 and shows ...
- Sep 24, 2016
If internet connectivity is working you should have seen that update.
If you set a static I.P. address check that the DNS server addresses are specified correctly.
mdgm-ntgr
Sep 24, 2016NETGEAR Employee Retired
Please update to 6.5.2 and send in your logs (see the Sending Logs link in my sig).
Is the NAS showing up in RAIDar and in the web admin UI with the correct 13 digit Serial Number that is printed on a label of the unit?
If you are trying to join it to ReadyCLOUD are you remembering to use your MyNETGEAR account?
- Geoff-SSep 24, 2016Aspirant
Hi.... I don't see 6.5.2 on the firmware download page linked in your footer.. just 6.5.1, and when I click on Check for updates on the admin page, it doesn't do anything. Do you have a direct link?
Yes the NAS shows up in both RAIDar and the web ui with the correct serial number.
I am a member of ReadyCloud and was able to access this NAS previously.
- StephenBSep 24, 2016Guru - Experienced User
You might also double-check that the ReadyNAS has internet connectivity. For instance if alerts are configured you could send a test message.
I will download and apply. The NAS has connectivity as I'm connected to it as a shared drive over my internal network. If there's something else you'd like me to check insofar as internet connectivity is concerned, please let me know and walk me through what you'd like tried. I don't have any alerts set up.
