Geoff-S
Sep 24, 2016Aspirant
Can't discover my ReadyNAS-104
I can't discover this device on ReadyCloud. I did have it set up at one time, and it stopped show up, so I removed it from ReadyCloud so I could try re-adding it. It is on firmware 6.5.1 and shows ...
- Sep 24, 2016
If internet connectivity is working you should have seen that update.
If you set a static I.P. address check that the DNS server addresses are specified correctly.
Geoff-S
Hi.... I don't see 6.5.2 on the firmware download page linked in your footer.. just 6.5.1, and when I click on Check for updates on the admin page, it doesn't do anything. Do you have a direct link?
Yes the NAS shows up in both RAIDar and the web ui with the correct serial number.
I am a member of ReadyCloud and was able to access this NAS previously.
Sep 24, 2016Guru - Experienced User
You might also double-check that the ReadyNAS has internet connectivity. For instance if alerts are configured you could send a test message.
- Geoff-SSep 24, 2016Aspirant
I will download and apply. The NAS has connectivity as I'm connected to it as a shared drive over my internal network. If there's something else you'd like me to check insofar as internet connectivity is concerned, please let me know and walk me through what you'd like tried. I don't have any alerts set up.
- mdgm-ntgrSep 24, 2016NETGEAR Employee Retired
Sorry I wasn't being beligerant with my reply... the IP addresses are static... there are no DNS entries for either NIC, so I've set them to what my ipconfig shows for my PC... the router's address of 10.0.1.1, and successfully sent a test alert email. Logging back in to ReadyCloud, my NAS appears without even asking for a discovery. Thanks guys for the fast replies!
