marco79p
Aug 23, 2025Aspirant
Readynad duo v2 root danneggiata e disk failure
Buon giorno a tutti , posseggo questo nas da parecchio tempo , circa 2 settimane fà ha smesso di funzionare , emetteva un suono ciclico costante metallico , tipico degli hard disk tralaltro , uno dei...
- Sep 01, 2025
I mark this discussion as resolved because while waiting for the SATA/USB adapter I tried to install the new disks and the NAS does nothing, it is not possible to access the web interface, I tried to perform the reset, but nothing has changed, so the NAS is dead and I just have to recover the data as you described with Linux, so this discussion is to be considered closed, or resolved, I thank everyone for the time you have dedicated to me, I thank you and I wish you many beautiful things, not only in this world where however you are very good and competent, thanks again for everything, "Ciao", Marco from Padua, Italy.
marco79p
Aug 24, 2025Aspirant
Thanks, so yes on the front panel it says v2 and I ordered an adapter similar to the one you recommended, so for now thanks everyone, I will try to do everything you recommended, thank you all very much.
marco79p
Sep 01, 2025Aspirant
