cmarino3
Jun 08, 2021Aspirant
ReadyNAS 102 - backup of network computer
Hello, I own a ReadyNAS 102 and have always used it as a "direct storage" unit (just by sharing folders on the network and accessing them from computers on the network). Never used it for cloud backu...
Jun 17, 2021Guru - Experienced User
cmarino3 wrote:
I need to automatically backup a specific folder (eg: "Photos") on a network computer (eg: \\SERVER) but I don't understand how to do it.
FWIW, I suggest that you run backup software on the PC that backs up the the NAS instead. FreeFileSync is one of several programs you can use.
But if you want to use a NAS backup job, then the first step is that you need to share the Photos folder on the Windows PC. There is some information on how to do that here: https://support.microsoft.com/en-us/windows/file-sharing-over-a-network-in-windows-10-b58704b2-f53a-4b82-7bc1-80f9994725bf
You'll want to require a username/password to access that share over the network (whether from the NAS or another PC). If you are using a microsoft (email-style) login, you should create a local account on the PC, and use it's username/password.
If you are already using a local account on the PC, then you can use your account name and password.
cmarino3 wrote:
- Do I have to set "Remote" rather than "Local" since the folder is on another computer on the network, and not on the NAS?
Yes.
cmarino3 wrote:
- how do i specify that I want to access \\SERVER computer? (eg: \\192.168.1.99)
- how do I specify I want to backup the \\SERVER\Photos folder?
Enter \\192.168.1.99 in the host field
Enter Photos in the share field.
cmarino3 wrote:
- how do I deal with username and password?
Enter the username and password that you need to use to get access to the PC share.
