hippocrite
Jul 03, 2017Aspirant
ReadyNas 102 - Not working after firmware 6.7.4 upgrade
Hi My Readynas 102 (RN-10200-100EUS) has been working flawless for a couple of years with the firmware it was shipped with. Now I have updated the firmware a couple of times from the admin page a...
hippocrite
Update:
By being really quick after a couple of reboots I managed to briefly access the fwbroker site and uploaded the 6.7.5 firmware.
Raidar showed 6.7.5 after another reboot but now the unit is stuck in "Upgrading"
I have tried the USB recovery method with no luck, still stuck in "upgrading"
I have tried OS Reinstall and Volume Read Only but still no progress.
I have family photos on the disk. Is it possible to reinstall OS on another new disk and then connect the existing disk afterwards and
access the data?
Regards
Hippo
- StephenBJul 04, 2017Guru - Experienced User
access the data?
No.
Netgear support (my.netgear.com) is probably the safest and quickest next step. Ask about per-incident support.
If you are experienced with linux, you can also mount the volume on a linux PC.
