ukbobboy01
Nov 02, 2023Apprentice
ReadyNAS 102 / OS6.2.5
Dear Forum Members I have just purchased from Ebay (UK) a ReadyNAS 106 running firmware 6.0.8 but, as most of you can guess, it is no longer possible to upgrade the firmware online, the only down...
- Nov 02, 2023
A simple Google of ReadyNAS 6.2.5 takes you here: ReadyNAS-OS-Version-6-2-5-RN102-RN104-Only
michaelkenward
Nov 02, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
ReadyNAS Network Storage: Official NETGEAR Community
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
