blushark's avatar
blushark
ReadyNas 102 2013 - compatible version
My readynas (2013) finally died. The drives are ok, its just that the unit does not boot up or read the drives. What versions of readynas are compatible where I can just swap out the drives to anothe...
  • StephenB's avatar
    Mar 24, 2022
    Often this is just the power brick - which can be replaced very easily.  So perhaps do a risk-buy of a replacement.
    blushark wrote:
     What versions of readynas are compatible where I can just swap out the drives to another readynas device?
    RN102, RN104, RN202, RN204, RN212, RN214 are all Arm ReadyNAS that run OS-6.  If you migrate to those, then your installed apps will still work.
    There are a lot more x86 OS-6 ReadNAS models - RN31x, RN42x, RN51x, RN52x, RN62x, RN71x models (where "x" is the number of bays).  You can directly migrate to those as well - data will all be there.  But any arm-specific apps will no longer work.
    The older ReadyNAS Pro, Ultra, and Ultra Plus models can be converted to OS-6 (which requires a spare disk).  Once converted, you can directly migrate to those (though since they are x86, arm-specific apps will also no longer work).
ProSupport for Business
