toshko37
Feb 01, 2018Follower
readynas 102 Backup: Error backup job backupArhive: Destination is read-only or files/folders could
Pleas for help readynas 102 job backup error ( 1y work normaly ) logs: Mon Jan 22 2018 20:14:42 Backup: Error backup job backupArhive: Destination is read-only or files/folders could not be created...
Marc_V
Feb 01, 2018NETGEAR Employee Retired
Hi toshko37
Welcome to the Community!
Can you verify that the Destination folder has read/write access, or the account you are using to access it has write access. You may want to try to reset the permissions of that folder.
You may want to check if there are files or folders that has been added which has a long filename that might exceed 250 characters including the complete path e.g (C:\Program Files\filename.txt)
Regards
