mrd
Jul 03, 2013Aspirant
ReadyNAS 102 Bug list.
- Disk usage is reported incorrectly by GUI - Disk usage graph is not reported correctly and does not match incorrecly or correclty reported actual usage number. - Alert email configuration can not ...
Jul 06, 2013Guru - Experienced User
mrd wrote: df is also incorrect. I created the exact same shares that were on my other ReadyNAS DUO V1 and rsync'd them. The size reported on the 102 is double. Why?
I'm not convinced df is incorrect. Not sure that is even possible w/o a corrupt file system.
In any event, I am not seeing this. Space reported in my shares (via windows) is exactly the same on my RN102 backup and the Pro. du . -S gives the same answer. Total space is consistent - and certainly it is not a factor of 2 off. That would put more stuff on the disk than it can hold.
I am wondering if the missing space is in your snapshots. Try deleting the snapshots and try again. You could also try scrubbing the volumes.
Can you clarify this a bit? Do you mean that if there is a network outage while a backup in running, that the backup never completes? Or that there is a bug in the reporting?
mrd wrote: If there is a network outage, any scheduled backups will be frozen in the in progress state.
