mrd
Jul 03, 2013Aspirant
ReadyNAS 102 Bug list.
- Disk usage is reported incorrectly by GUI - Disk usage graph is not reported correctly and does not match incorrecly or correclty reported actual usage number. - Alert email configuration can not ...
Aug 09, 2013Guru - Experienced User
It might be possible to have an power setting that says "shut the system down at time X but if the disks are active wait until they have been inactive for M minutes".
pantatechnics wrote: Suppose you configure Power timer to shut down at 01:00 am.
If you do a data transfer between your pc and readynas, when the time for shut down comes the nas, begins a shut down proccedure witout any notice or
ask for shut own confirmation
But I don't see how the NAS could ask for user confirmation on your PC when you are using SMB. Or FTP, DLNA, iTunes Server, AFP, NFS, etc. There is no mechanism for it to use.
If you want to reduce power usage while leaving the NAS available, then why not use "enable disk spin-down"?
By default the RN102 has snapshots enabled. Any deleted files are shifted to the snapshot (so no space is freed up).
pantatechnics wrote: ...As for the wrong disk usage indication, when i delete a big amount of data, the gauge dows not subtructi the deleted amount to show the new usage.
