mrd
Jul 03, 2013Aspirant
ReadyNAS 102 Bug list.
- Disk usage is reported incorrectly by GUI - Disk usage graph is not reported correctly and does not match incorrecly or correclty reported actual usage number. - Alert email configuration can not ...
pantatechnics
Aug 26, 2013Aspirant
At the very new OS 6.1.1 Antivirus function could not be enabled.
When you clik it ask you if you want to enable it, if click ok it seems it is enabling but at least does not enable it.
The Antivirus tab it has not the green bar.
At the previous version 6.0.8 worked normaly.
I have to say congratulations to the firmware developers, they do their best to make the readynas a perfect nas solution.
