mrd
Jul 03, 2013Aspirant
ReadyNAS 102 Bug list.
- Disk usage is reported incorrectly by GUI - Disk usage graph is not reported correctly and does not match incorrecly or correclty reported actual usage number. - Alert email configuration can not ...
mrd
Sep 06, 2014Aspirant
Since I started this thread, I wanted to make sure anyone with the same recent problems I have dealth with can find the answer here:
SOLVED!
Rsync:
After a factory default and reinstrall with the latest RN102 firmware availabel on the forums, I created all new shares in the exact same way as the first time and now was able to enable rsync password for all shares.
NFS:
It turns out that there was a firware bug with the Netgear Prosafe switch that this NAS is connected to. Netgear JGS524PE
A firmware upgrade resolved teh NFS issues.
I appreciate all of the help from the forum, which is what led me in teh direction of a possible network problem.
SOLVED!
Rsync:
NFS:
