PhilStark
Nov 04, 2019Aspirant
Readynas 102 FTP transfer speed ?
Hello all, I own a Readynas 102 and I have a question about FTP transfer speed. I checked in the community but couldn't really find an answer. When I copy/paste files from my computer to my Rea...
Nov 04, 2019Guru - Experienced User
- Is the FileZilla client also running on your local network?
- Is it set up to connect to the NAS by it's local IP address, or are you using a DDNS name?
- Are downloads running at the normal speed?
Also, what firmware are you running?
PhilStark
Thanks for your reply StephenB
- Yes, same local network.
- I'm using DNS name to connect. (EDIT : tried with IP address / same speed)
- D/L is faster (~10 Mio/s) than U/L (~3Mio/s) but still slow.
Thanks,
Phil
- StephenBNov 04, 2019Guru - Experienced User
FWIW, I get 10 megabytes a second upload and download using 6.10.2 firmware on my RN102 NAS and FileZilla 3.45.1. Not sure why I'm limited to that - I tried setting upload/download limits at 99999 KB/s on the NAS, but the speed didn't change.
Enable FTP and Enable FTPS were checked. Force FTPS was not. I had 4 passive ports allocated (though that shouldn't matter, since I was testing with a single file).
But you should be able to get 10 MB/s on the upload path too. Did you try testing from a different client PC?
