spangle_it
Jan 24, 2022Aspirant
Readynas 102 low disk space
HI I am running out of storage space and have plans to upgrade to a larger unit As an immediate fix to get more space I have copied off old data to a USB drive and deleted the data from the n...
Jan 24, 2022Guru - Experienced User
spangle_it wrote:
As an immediate fix to get more space I have copied off old data to a USB drive and deleted the data from the nas,
If you have snapshots enabled, then go in and delete them.
After you done that, then try running a balance (from the volume settings wheel).
- SandsharkJan 24, 2022Sensei
OS6 does not have a recycle bin (though many have asked that that OS4.x feature be added).
- spangle_itJan 24, 2022Aspirant
Thank you Stephen, trying that now
