PhilStark
Nov 15, 2020Aspirant
Readynas 102 Management service is offline after upgrade to 6.10.3
Hello After a long while offline, I restarted my ReadyNAS 102 and upgraded the firmware to 6.10.3 I had issues connecting to it and after a couple of froced shutdowns I got a "Management service...
Nov 15, 2020Guru - Experienced User
PhilStark wrote:
I do have files on one of the hd I don't want to lose. Could I remove only that one and do a factory reset ?
Not without access to the web ui or ssh. You'd need to export the volume first (which you can't do w/o access).
You could
- use paid netgear support (my.netgear.com); getting per-incident support if you can.
- try exerimental Windows software for btrfs and mdadm, and see if you can access the files that way. https://github.com/maharmstone/btrfs and https://github.com/maharmstone/winmd
- access the NAS in tech support mode (which requires linux skills). From there you could back up your files to a USB drive, and also export the volume that has the files you don't want to lose.
- Jun 10, 2022Retired_Member
