sergio_fucchi
Apr 21, 2019Guide
ReadyNAS 104 - Update from 6.9.5 to 6.10.0 problems.
Hi.
In my RNS 104 I had installed the firmware 6.9.5 patch 1 release and I downloaded and installed version 6.10.0. But at the time of the reboot after the upgrade the boot reaches 99% and then...
Apr 21, 2019Guru - Experienced User
Did you try powering down the NAS and restarting it?
- sergio_fucchiApr 22, 2019Guide
Sure. Twice, but the result is always the same. The boot stops at 99% and the power button LED continues to flash. As it happens for that of the activity. The discs make the classic noise of being active. It looks like the system is doing a rebuild.
- Equinox1Apr 24, 2019Guide
I had exactly the same symptoms tonight, after updating from UI.
There must a glitch in the upgrade process.
The easiest way to get out of the situation was to reinstall the firmware by SSH.
- quickly_nowApr 26, 2019Apprentice
And how do you do thius re-install via SSH please?
I have the same issue - wasted about 3 hours so far on this.
I tried to press the power button and the message apache2.service is appeared on the display
- StephenBApr 22, 2019Guru - Experienced User
Can you download the log zip file via RAIDar? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
If you can, the PM one of the mods ( JohnCM_S for example), or maybe Hopchen (former Netgear employee), and ask if they will analyze. You can send a link (google drive, dropbox, etc).
Don't post the link publicly, just use the PM (private message) facility of the forum. Click on the envelope icon in the upper left of the forum page.
