limesin's avatar
limesin
SXS50 firmware update problem
Hi
I have updated  SXR50 router first, before SXS50 satellite.
I have no idea how to update the satellite now, because there is no check box in router GUI to do that.
Every suggestion very welcome
Thx in advance.
  • Does SXS50 connect to SXR50 wirelessly? Or no, can you try wire SXS50 and SXR50 so you will see SXS50 is under SXR50 management.
  • BruceGuo's avatar
    BruceGuo
    NETGEAR Expert
    • limesin's avatar
      limesin
      Hi
      Thx for your reply.
      I'm just finishing the process of restore factory settings, and I can see under SXR50 the SXS50.
      I will try to update and then I will finish this post.
      WORKED!
      Both items has been updated.
      Anyway thanks for your help!
ProSupport for Business
