sergio_fucchi
Apr 21, 2019Guide
ReadyNAS 104 - Update from 6.9.5 to 6.10.0 problems.
Hi.
In my RNS 104 I had installed the firmware 6.9.5 patch 1 release and I downloaded and installed version 6.10.0. But at the time of the reboot after the upgrade the boot reaches 99% and then...
sergio_fucchi
Apr 22, 2019Guide
I tried to press the power button and the message apache2.service is appeared on the display
Apr 22, 2019Guru - Experienced User
Can you download the log zip file via RAIDar? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
If you can, the PM one of the mods ( JohnCM_S for example), or maybe Hopchen (former Netgear employee), and ask if they will analyze. You can send a link (google drive, dropbox, etc).
Don't post the link publicly, just use the PM (private message) facility of the forum. Click on the envelope icon in the upper left of the forum page.
