phantomwcs
Apr 27, 2019Aspirant
ReadyNAS 104 and macOS Mojave 10.14.4 very slow access
Firmware 6.10.0
WD SATA 3TB x3
2.93 TB used, 2.34 TB free
MacBook Pro running Mojave 10.14.4
Using smb access to several shares. Fpr example: smb://PEARL01._smb._tcp.local/Documents
I a...
schumaku
May 02, 2019Guru - Experienced User
Roger,
phantomwcs wrote:
I am seeing very slow access via mac's Finder. It will time to display the contents of a directory. I often also get a "verifying file" popup. In searching I found many threads on disabling SMB and using AFP, but now it seems SMB is the only option for mac
For a while, Apple had the (not so) brilliant idea to force enable SMB signing on the (up to 10.13.3) - this is what made up the idea changing to AFP does creatre a faster connection aain in the past - starting from 10.13.4 this default was chaned again (hey Netgear, it is possible to change specs and implementation when they are causing bad user impression!). Worth checking that SMB signing is disabled anyway -> https://support.apple.com/en-us/HT205926
MacOS does still support AFP - for legacy connections only - but it does not give the option if there are Bonjour annoucements forthe same host (NAS) with both SMB and AFP, making SMB the default.
