mmetalfan
Jan 30, 2020Aspirant
ReadyNAS 104 kmem_cache_alloc+bc on boot error
Hello I recently ran the firmware upgrade through the web portal on the NAS to 6.10. Currently I am not sure what the exact previous firmware version was, but I update it fairly regularly when I...
mmetalfan
I got it to finally boot when I removed the HDDs from the machine.
Once booted, I added the drives back into their same ports 1 at a time.
However, now I am not seeing any of my data or my shares.
Only thing that is still there are the user accounts.
Message I am getting is remove inactive volumes to use the disk.
How do I go about getting my data back. It should all be there as I have not created any new volumes or formatted them.
Thank you
- StephenBJan 31, 2020Guru - Experienced User
That was a mistake, though I don't think it would do more damage.
The best way is to contact paid Netgear support (my.netgear.com).
Per-incident support might be enough to get the data volume mounted - I think the cost would be about $75 USD. JohnCM_S and Marc_V can help you sort out if per-incident support is the right avenue.
Of course if you have a backup, you can alternatively do a factory default and restore the files from the backup. After you recover your data (thinking positive!), I suggest that you put a backup plan in place for the NAS.
