ERN
Dec 31, 2015Aspirant
Readynas 104 OS 6.4.1 not responding proper
Hi! I have two 104's one with 4*4TB and the other with 4*2TB and both seem to have issues now after I updated to 6.4.1.... both in Raid 10 I cannot copy anything from or to them as the speed is dow...
mdgm-ntgr
Dec 31, 2015NETGEAR Employee Retired
Happy New Year!
Which services/apps are you running?
Which firmware did you update from?
Can you send me your logs (see the Sending Logs link in my sig)?
Welcome to the Community!
- ERNDec 31, 2015Aspirant
Hello!
Thank you, rather new to this.
A happy new year to you also.
I'm not running any apps at all, only the services SMB, NFS, Ready DLNA, HTTP, HTTPS and AntiVirus.
Upgraded from 6.4.0
I do have the Bit-rot protection turned on.
Logs? Unfortunately I had them removed earlier yesterday, saw nothing as warnings or errors just information, thus that action taken.
The thing that I noted about the snapshot function, which I had to disable as it seemed to be taking one each hour os so, had 58 of them taking 1.25 TB
and the first one was from late 2013 sep-oct. Once a month should have been about 24, so after update about 30 something taken.
Erased all except the last one.
All the best
Eie
- mdgm-ntgrDec 31, 2015NETGEAR Employee Retired
Well you could send them in anyway.
There is a known issue on 6.4.1 where performance may be poor with the anti-virus service enabled.
Whilst we don't have a fix for that particular issue yet, we do have some beta firmware: https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-4-2-T59-Beta-1/td-p/999457/jump-to/first-unread-message
- mdgm-ntgrJan 02, 2016NETGEAR Employee Retired
Have you tried disabling the anti-virus service and/or updating to the beta firmware as mentioned in my previous post?
