ERN
Dec 31, 2015Aspirant
Readynas 104 OS 6.4.1 not responding proper
Hi! I have two 104's one with 4*4TB and the other with 4*2TB and both seem to have issues now after I updated to 6.4.1.... both in Raid 10 I cannot copy anything from or to them as the speed is dow...
mdgm-ntgr
Dec 31, 2015NETGEAR Employee Retired
Happy New Year!
Which services/apps are you running?
Which firmware did you update from?
Can you send me your logs (see the Sending Logs link in my sig)?
Welcome to the Community!
ERN
Hello!
Thank you, rather new to this.
A happy new year to you also.
I'm not running any apps at all, only the services SMB, NFS, Ready DLNA, HTTP, HTTPS and AntiVirus.
Upgraded from 6.4.0
I do have the Bit-rot protection turned on.
Logs? Unfortunately I had them removed earlier yesterday, saw nothing as warnings or errors just information, thus that action taken.
The thing that I noted about the snapshot function, which I had to disable as it seemed to be taking one each hour os so, had 58 of them taking 1.25 TB
and the first one was from late 2013 sep-oct. Once a month should have been about 24, so after update about 30 something taken.
Erased all except the last one.
All the best
Eie
- mdgm-ntgrDec 31, 2015NETGEAR Employee Retired
Well you could send them in anyway.
There is a known issue on 6.4.1 where performance may be poor with the anti-virus service enabled.
Whilst we don't have a fix for that particular issue yet, we do have some beta firmware: https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-4-2-T59-Beta-1/td-p/999457/jump-to/first-unread-message
- mdgm-ntgrJan 02, 2016NETGEAR Employee Retired
Have you tried disabling the anti-virus service and/or updating to the beta firmware as mentioned in my previous post?
- ERNJan 03, 2016Aspirant
Hi again!
I have now disabled AV and that does work as far as I can tell now, doesn't feel that good, as security is always at the prio list.
I would rather not install any Beta versions, have had some past issues regarding that (not with Netgear).
BR
Eie
