Tinnsoldaten
Dec 31, 2021Aspirant
ReadyNas 104 remove bonded network
How to remove bonded network? I tried in the menu to select delete but after regaining access to menu, bond0 is still there. Second question. I just got new TV, issue is that LAN cabl...
- Jan 08, 2022
Tinnsoldaten wrote:
What switch would you choose this purpose ?
D-Link Web Smart DGS-1210-10P PoE Switchor
TP-Link TL-SG108E Unmanaged, QoS, IGMP Snooping
The TP-Link would be fine - no need for a managed switch. If course if you have PoE devices, then a PoE switch would make sense - but otherwise would just waste money.
The Netgear GS108 would also work.
Dec 31, 2021Guru - Experienced User
Tinnsoldaten wrote:
Port 0 on NAS is connected to ISP router. This allow TV to get acces via LAN to internet, but I dont see NAS.
Any way I can setup NAS so that I regain full connection with TV-NAS-PC ?
The Deco M5 is a router, so you are double-routing. That's why the TV isn't finding the NAS.
Options are
- disable routing on the Deco (not sure if this is possible - I'm not seeing it in the manual)
- connect all your devices to the Deco, and disable the WiFi in the ISP router.
What firmware are you running on the RN104?
Any warnings about the OS (root) partition being full?
Tinnsoldaten
I am thinking of placing something instead of mesh next to tv , switch maybe, I think that might solve the issue with seeing NAS, not sure, my networking skills are rusty...
The Deco only have 2 ports , I need 4 in to manage.
About disabling router function, if I leave Deco without power, will it become a switch ?
My NAS have latest firmware. 6.10.6
Yes, I have a less than 10% capasity message in log
About that, I was deleting loads of files from NAS, but no change in size free.
