Tinnsoldaten
Dec 31, 2021Aspirant
ReadyNas 104 remove bonded network
How to remove bonded network? I tried in the menu to select delete but after regaining access to menu, bond0 is still there. Second question. I just got new TV, issue is that LAN cabl...
- Jan 08, 2022
Tinnsoldaten wrote:
What switch would you choose this purpose ?
D-Link Web Smart DGS-1210-10P PoE Switchor
TP-Link TL-SG108E Unmanaged, QoS, IGMP Snooping
The TP-Link would be fine - no need for a managed switch. If course if you have PoE devices, then a PoE switch would make sense - but otherwise would just waste money.
The Netgear GS108 would also work.
Tinnsoldaten
This is my current setup
Dec 31, 2021Guru - Experienced User
Is routing enabled on the Deco?
What IP address range are you using for the Deco? Also what address range are you using for the ISP router?
What firmware is running on the RN104?
No matter how the Deco is set up, having bonding enabled on the RN104 is also going to be a problem.
But I am still thinking that double-routing is getting in the way here, especially if the TV is using DLNA. That won't go through a NAT firewall (and the Deco is providing that if it is in router mode).
FWIW, I also double-route, but everthing is connected to my inner router (which is an Orbi mesh).
- TinnsoldatenDec 31, 2021Aspirant
Taking power from the mesh connected to TV did not work, just lost connection all together.
Im wondering about taking care of the space issue on my NAS, then try solve the bonding issue.
I did see NAS on TV before I managed to enable bonded network cards.- TinnsoldatenDec 31, 2021Aspirant
Volume: Less than 10% of volumes data's capacity is free. Data's performance is degraded and risk running out of space.
To improve performance and stability, you must add capacity or free space.
Why I cant see more free space when deleting files on NAS?- TinnsoldatenDec 31, 2021Aspirant
Deco have IP 10.0.0.1
and ISP have : 85.167.249.82
