Tinnsoldaten
Dec 31, 2021Aspirant
ReadyNas 104 remove bonded network
How to remove bonded network? I tried in the menu to select delete but after regaining access to menu, bond0 is still there. Second question. I just got new TV, issue is that LAN cabl...
- Jan 08, 2022
Tinnsoldaten wrote:
What switch would you choose this purpose ?
D-Link Web Smart DGS-1210-10P PoE Switchor
TP-Link TL-SG108E Unmanaged, QoS, IGMP Snooping
The TP-Link would be fine - no need for a managed switch. If course if you have PoE devices, then a PoE switch would make sense - but otherwise would just waste money.
The Netgear GS108 would also work.
Tinnsoldaten
Jan 07, 2022Aspirant
or
Jan 08, 2022Guru - Experienced User
