jonnymcc
Dec 29, 2019Aspirant
ReadyNAS 104 replaced 1 disk now no data
Hi, I was generally happy with my ReadyNAS 104 for several years but recently a disk was predicted as failing so I ordered a new one (another WD red 3TB). When I replaced the disk the NAS display sai...
jonnymcc
That's a bit expensive for my budget so I'll have to create a new volume and try to recover what I can from backups. I'm a bit disappointed though that replacing a disk in a raid-5 lost everything - doesn't fill me with confidence.
Dec 29, 2019Guru - Experienced User
You could try deleting one of the volumes, and see if it comes back. But I'm not sure which one. JohnCM_S or Marc_V might be able to tell - try downloading the logs and send them a downloadable link via PM (private message). You'd do that using the envelope icon in the upper right of the forum page.
