Mingles
Feb 22, 2020Follower
ReadyNAS 104 Share has dissapeared
Hi there... After spending a good couple of hours browsing through these forums and seeing people with similar issues, i have tried all the suggestions on here but can't seem to get my one of my ...
Sandshark
Feb 22, 2020Sensei
My best guess is that the volume isn't mounted properly, but probably still exists (though possibly damaged). If it's not mounted, then the directory that is it's mount point can't contain a BTRFS sub-volume, which is what a share is, so creating a new one will fail. I don't know if the mods can gain enough insight from your logs or not, but I'd try that first. Does it show up in the mount list (cat /proc/mounts)? What do you see when you do a btrfs subvolume list /data or ls /data -all (or whatever the volume name is in place of "data")?
