Spanfan
Jan 13, 2025Tutor
ReadyNAS 104 Slow file transfer and access
For the last 2 days I'm having problems with my READYNAS 104 v6.10.10 which has 4 x 2Tb drives in. I cannot access the admin page via 192.168.1.2 which sticks at the splash screen. I can see all th...
Spanfan
Jan 13, 2025Tutor
My apologies for posting in the wrong group and thanks for moving it. I has assumed it came under legacy routers as it is no longer supported.
I have tried suggested tips but am restricted as I am unable to access the Admin page or download logs. If necessary I'm prepared to buy another router if I can transfer the 4 disks and not lose the media.
- StephenBJan 13, 2025Guru - Experienced User
Do you mean buy another NAS???
I am thinking that you have no backup for the data - is that correct?
Have you tried downloading the logs from RAIDar?
- SpanfanJan 13, 2025Tutor
Yes, slip of the fingers, another NAS and I have no backup for the approx 7Tb of data on the 4 discs so was wondering if there is another Netgear NAS that is compatible that I could just put the disks into and they would work. I did try to copy some of the files using Windows but the transfer rate is so slow it would be impossible to backup any useful amount.
I've tried downloading logs via Radarr but it says "not a valid username and password even though it is the correct one.I used for the Admin page in the past The same thing happens if I try Diagnostics in Radarr
I have finally managed to get into the admin page. I can select between the various menu options but no matter which option I select nothing opens so can't view the shares, settings or logs etc, just a wheel turning in centre of screen
