chersoph
Jan 01, 2018Aspirant
ReadyNAS 104 slow responding from web interface and slow file transfer
Hello, My RadyNAS 104 is very slow at responding via the web interface and slow at file transfer. I use it for storing media files that I access from a Mac running Plex. I've noticed that Plex says ...
Jan 02, 2018Guru - Experienced User
What apps are installed and what services are enabled?
chersoph
Jan 02, 2018Aspirant
Hej,
I have no apps running. Services running are AFP, HTTP, HTTPS, and SSH. Im not sure if I can close down all but AFP which is what a basically need for Plex on the mac to access the NAS.
//Erik
- StephenBJan 03, 2018Guru - Experienced User
So that's already minimal (no antivirus, no apps, no file protocols you aren't using).
You could try rebooting the NAS, and see if that helps.
Another thought is that you could enable SMB, and try using that with plex instead of AFP. I'm not sure which will work better, since I'm not a Mac user.
