shaunyp
Oct 02, 2019Aspirant
Readynas 1500 Corrupt Root
We were gifted a ReadyNas 1500 which are trying to get up and running. We have bought 4 x WD red 3TB drives and installed. The Nas has a DHCP address which I can ping and can see on RAIDar, however I...
Oct 02, 2019Guru - Experienced User
I suggest trying Lifeguard again, and use the full erase test. That can sometimes pick up issues that the non-destructive test misses.
You can try that with just one drive (leaving the other slots empty). When you power up the NAS with a zeroed drive, it should do a factory install automatically (using XRAID). It will come up pretty quickly, since there is no RAID sync involved.
If that works, you can then hot-insert the remaining drives one at a time - waiting for resync and expansion to complete before moving on to the next.
shaunyp
Oct 04, 2019Aspirant
Thanks Stephen, unfortunately full erase crashed after about 15 hours, however I zeroed a 120gb ssd and slotted it in and hey presto it worked. Now added remaining drives and all being raided so good news.
Thanks for your suggestion
