MarkRowe
Apr 04, 2020Aspirant
ReadyNAS 2100 Caddy
Can I purchase two spare Hard Drive Caddies for my ReadyNAS 2100 ? Also, can I purchase the two 19" Rack Mounting Brackets (sometimes refered to "ears"), as I cannot find the ones supplied with my u...
- Apr 05, 2020
Sandshark, thank you for a very detailed reply. I have compared both the Chenbro and Netgear 1100 caddies and decided that if I am going to take a chance I will obtain the 1100 ones (only becase the Chenbro ones don't have the screws holes in the base of the caddy), like the Netgear ones. I also have a ReadyNAS 3138 on my Network, and I have tried those caddies in my ReadyNAS 2100 but they are too wide so will not fit.
As for the Rack Ears, I am yet to find suitable replacements here in the UK so may have to fabricate a pair myself out of aluminum angle.
Many thanks again for your reply, it was extremely helpful.
MarkRowe
Apr 05, 2020Aspirant
MarkRowe
Apr 09, 2020Aspirant
Just to confirm the Netgear 1100 caddies will fit nicely into a ReadyNAS 2100.
