RDunkley
Mar 29, 2017Aspirant
readyNas 2100 FTP issues
I have the 2100 series and have updated it to version 4.2.30 FTP no longer works properly. I can connect to the FTP share as the administrator but not as any other user. It is setup in a dom...
JennC
Mar 31, 2017NETGEAR Employee Retired
Hello RDunkley,
Are you trying this locally? Perhaps try re-configuring the FTP permission of one share and/or add a new user to test. Please post the things you have also tried.
Welcome to the community!
- JennCApr 03, 2017NETGEAR Employee Retired
Hello RDunkley,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards, - RDunkleyApr 04, 2017Aspirant
I will try a local user, but NONE of the domain user credentials work.
Rob
When I first open the connection I see warnings:
500 AUTH not understood
KERBEROS_V4 rejected as an authentication type
Rob
