vitaliyvolkov
Sep 30, 2019Aspirant
ReadyNAS 2100 goes down
Hello. Not sure if I am posting the thread in the correct section, so move it somewhere else if I did something wrong. I will try to explain the trouble briefly. I have ReadyNAS 2100 in the company ...
- Dec 16, 2019
I finally got the reason why the NAS was instable. The reason are CIFS shares. These shared were added as Veeam backup repositories. I have removed these shares to add as iSCSI targets to the Veeam server afterwards. The NAS is stable now.
Oct 08, 2019Guru - Experienced User
When you disabled LACP, did you remove the second NIC cable?
Is the NAS only hosting iSCSI LUNs? Do you know what LUN is causing the error? Are you seeing any operational issues with the device that is running the iSCSI initiator?
vitaliyvolkov
Oct 08, 2019Aspirant
Of course, I did. The NAS has 1 CIFS resourse which is used by 1 server and 4 iSCSI targets for 4 different servers, no iSNS. The servers are fine, no errors, nothing suspicious. When the NAS goes down, it's getting unavailable for everything.
- StephenBOct 08, 2019Guru - Experienced User
vitaliyvolkov wrote:
Of course, I did.
You'd be surprised on how many people don't.
You might need paid support for this problem. Or perhaps just replace the NAS? It is pretty old at this point.
- vitaliyvolkovOct 08, 2019Aspirant
I know, it's old and hence I hold nothing critical there. I just don't get why this problem happens to this NAS cause I have 3 NAS of the same manufacturer and device model. They all are identical, but one of them is not stable.
- StephenBOct 09, 2019Guru - Experienced User
It might be caused by failing memory, or some other system board component.
