Mr__Bear
Nov 08, 2012Aspirant
ReadyNAS 2100 Increasing Command Timeout on Disk 3
Hi... We have a ReadyNAS 2100 with 4x2TB drives (Seagate ST32000644NS SN12) that has been in service for a couple of years. Disk 3 was replaced last year with a downright drive failure. The f...
Mr__Bear
Here is the portion of the log showing sata5 being downgraded to 1.5Gbps from 3.0Gbps -
Nov 7 07:15:40 emboar kernel: ata5.00: status: { DRDY }
Nov 7 07:15:40 emboar kernel: ata5.00: failed command: WRITE FPDMA QUEUED
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/90:50:50:91:a2/00:00:08:00:00/40 tag 10 ncq 73728 out
Nov 7 07:15:40 emboar kernel: res 40/00:b0:c8:9c:a2/00:00:08:00:00/40 Emask 0x10 (ATA bus error)
Nov 7 07:15:40 emboar kernel: ata5.00: failed command: READ FPDMA QUEUED
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 60/80:58:48:98:3d/00:00:04:00:00/40 tag 11 ncq 65536 in
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/40:60:48:9c:a2/00:00:08:00:00/40 tag 12 ncq 32768 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:68:b8:97:60/00:00:01:00:00/40 tag 13 ncq 4096 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/18:70:c8:97:a2/00:00:08:00:00/40 tag 14 ncq 12288 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/38:78:90:8d:a2/00:00:08:00:00/40 tag 15 ncq 28672 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:80:c8:90:a2/00:00:08:00:00/40 tag 16 ncq 4096 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:88:d0:90:a2/00:00:08:00:00/40 tag 17 ncq 4096 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/78:90:d8:90:a2/00:00:08:00:00/40 tag 18 ncq 61440 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/10:98:e0:91:a2/00:00:08:00:00/40 tag 19 ncq 8192 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/20:a0:c8:9b:a2/00:00:08:00:00/40 tag 20 ncq 16384 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/60:a8:e8:9b:a2/00:00:08:00:00/40 tag 21 ncq 49152 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/48:b0:c8:9c:a2/00:00:08:00:00/40 tag 22 ncq 36864 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/90:b8:00:8d:a2/00:00:08:00:00/40 tag 23 ncq 73728 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/18:c0:08:92:a2/00:00:08:00:00/40 tag 24 ncq 12288 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:c8:38:93:a2/00:00:08:00:00/40 tag 25 ncq 4096 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:d0:08:93:a2/00:00:08:00:00/40 tag 26 ncq 4096 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/28:d8:10:93:a2/00:00:08:00:00/40 tag 27 ncq 20480 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:e0:40:93:a2/00:00:08:00:00/40 tag 28 ncq 4096 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/08:e8:c8:90:60/00:00:01:00:00/40 tag 29 ncq 4096 out
Nov 7 07:15:40 emboar kernel: ata5.00: cmd 61/28:f0:60:97:a2/00:00:08:00:00/40 tag 30 ncq 20480 out
Nov 7 07:15:40 emboar kernel: ata5: hard resetting link
Nov 7 07:15:40 emboar kernel: ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Nov 7 07:15:40 emboar kernel: ata5.00: configured for UDMA/133
Nov 7 07:15:40 emboar kernel: ata5: EH complete
Nov 7 07:16:08 emboar kernel: WRITE_SAME w/o UNMAP bit not supported for Block Discard Emulation
Nov 7 07:19:17 emboar RAIDiator: Detected increasing command timeouts on disk 3 [8, 7]
Nov 7 07:19:17 emboar RAIDiator: Current (temp, start_stop_cnt, power_on_hrs, power_cycle_cnt, load_cycle_cnt) = (35, 1, 13, 1, 1)
Nov 7 07:21:03 emboar kernel: WRITE_SAME w/o UNMAP bit not supported for Block Discard Emulation
Nov 7 08:52:07 emboar kernel: WRITE_SAME w/o UNMAP bit not supported for Block Discard Emulation
Nov 7 09:04:54 emboar kernel: WRITE_SAME w/o UNMAP bit not supported for Block Discard Emulation
Nov 7 09:20:29 emboar kernel: WRITE_SAME w/o UNMAP bit not supported for Block Discard Emulation
