SKYLINE643
Nov 12, 2023Aspirant
ReadyNAS 2100 stuck when booting
My ReadyNAS 2100 is stuck when booting. I can't access the device via the webpage after a factory reset. The RAIDiator tool doesn't show a firmware version, only the message "corrupt root". I can pin...
Nov 12, 2023Guru - Experienced User
Did you try a second factory reset?
- SKYLINE643Nov 15, 2023Aspirant
After long trying, I've been able to do a full factory reset. I had also 1 disk (with errors - so I replaced it).
When the factory reset was done, the system made a new RAID, and I could access it via an old Opera version.
It seems this old NAS doesn't support HTTPS? I didn't find a way to generate an SSL certificate?
One fan is broken, I need to find spare parts for this, but is also hard to find...
If someone has some advice, please shoot!- StephenBNov 15, 2023Guru - Experienced User
It seems this old NAS doesn't support HTTPS? I didn't find a way to generate an SSL certificate?It will generate a self-signed cert.
But more likely your issue is because the NAS only supports TLS 1.0, and current browsers have deprecated that. There is a long thread on the subject here:
There is an add-on you can install (courtesy of WhoCares_ ) here:
Ok, thanks for your fast reply. I will try this.
