ExactSys
May 16, 2018Aspirant
Readynas 2100 v1 motherboard replacement
Is there anywhere i can purchase a replacement motherboard for the readynas 2100 v1?
I have two which are completely bricked and i was wondeirng if there is a known place i can buy a replacemen...
ExactSys
Hi mdgm,
I have followed the documents for creating a USB boot recovery key. Also i tried holding down the backup button for 15 seconds when booting up. Waited an hour nothing had happened, blue light still flashing away on the front and fans spinning loudly. I have held that button in for a good couple of minutes on boot still the same.
I was under the impression the USB light should at least light up when a USB key is in there regardless of what's actually on it. Either way it does not illuminate at any time (apart from start up in the light sequence so i know the light works!).
May 16, 2018Guru - Experienced User
The instructions say to hold down the reset button on rackmount units, not the backup button. https://kb.netgear.com/30267/RAIDiator-4-2-USB-Recovery-Tool
- ExactSysMay 16, 2018Aspirant
I tried that also, if you hold down the reset button on boot it lights up all the lights on the front and you can toggle through them which equate to a different boot. In the documentation none of those are 'USB boot'. I have tried factory default on this option, hear it reboot but after an hour nothing has happened. I thought perhaps to USB boot for the factory restore you hold the reset button down for 15 seconds or more on boot and then just leave it with all lights on. Once again after half hour of nothing happening i concluded it had not worked.
- Marc_VMay 21, 2018NETGEAR Employee Retired
Hi ExactSys
Welcome to the Community!
Unfortunately there's no available replacement parts or board for the ReadyNAS System, Your best chance is to come upon a refurbished ReadyNAS 2100.
Regarding the USB Boot Recovery, how many USB keys have you tried using (You might need to try more)? For Rackmount models Reset button should be held before powering up the NAS.
If your USB drive has LED indicators once it is lit you should release the Reset button, NAS shutting down will inidicate that the recovery is succesful. Try powering off the NAS completely then holding the reset button before bringing back power.
Hope this helps!
Regards
- ExactSysMay 22, 2018Aspirant
Hi Marc_V
Out of interest if this OS6 non compatible NAS was attempted to be upgraded to OS6, what recovery media should I be using, as I have been uisng the 4.2 one. I think i may have tried OS6 as a long shot the other week but cannot confirm that.
I've tried 3 USB sticks, I'll bring in more from home and try them all! As the three i used did not light up the nas USB light or the USB light.
Thanks.
