SamirD
Aug 27, 2020Prodigy
ReadyNAS 2100 won't boot, disk lights on, power light off
So my lights are the same as in this previous thread: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-2100-won-t-boot-disk-lights-on-power-light-off/m-p/919786#M63715 U...
Sandshark
Aug 28, 2020Sensei
This is a new NAS to you, so are the drives also new to the NAS? Have you ever had a working volume in this NAS? If the drives are not new, is there something on them you want to preserve?
Access to SSH is controlled by the OS configuration saved on the drives, not anything in hardware.
One thing to try is to use your Ultra6 to create a single-drive volume and then move that to the 2100. Just remove the drives from the Ultra with power off and start fresh with a spare drive. Then you can power off and swap the old drives back in.
I thought there was a difference between the rack and desktop caddies, though they look similar. But maybe that's just for the 1000 and 1100 rack mount units.
SamirD
Aug 28, 2020Prodigy
The drives were running in the nas, so there was a working volume I believe unless it was factory reset before being sold to me. I'm assuming there isn't anything on the drives, so I would expect to be able to wipe/reset/whatever as needed. Hopefully I'll get some more clarifiction from this from the seller.
Yep, that's why I don't have ssh access and won't be able to try anything in the other thread. :(
Hmmm....this is a good idea. I already have a 12TB single drive volume in the Ultra 6 as a backup of a backup, so once the threat of tornados passes tonight, I can just move it to the 2100 and try booting it that way and see what happens. I was going to put a 16TB in the Ultra6 anyways.
I was pleasantly surprised with the caddies. Now I've got 10 caddies between two nas units. :) My long term deployement of these is to put them on either side of an ipsec vpn tunnel and have an rsync job that updates one from the other nightly.
