SamirD
Aug 27, 2020Prodigy
ReadyNAS 2100 won't boot, disk lights on, power light off
So my lights are the same as in this previous thread: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-2100-won-t-boot-disk-lights-on-power-light-off/m-p/919786#M63715 U...
Aug 28, 2020Guru - Experienced User
Did you try tech support mode?
SamirD
Aug 28, 2020Prodigy
So the seller mentioned that they may have gotten the disks out of order when putting them back in and recommended a factory reset, which I just initiated. Hopefully this will solve the issue. :)
- SamirDAug 28, 2020Prodigy
So it must have worked! The unit is rebuilding one of the drives for some reason, but the empty shares are visible and working and can even transfer 30MB/s during the rebuild. :) I'm happy.
It's also nice that the interface is a twin of the Ultra6 so setting them up to be the same will be a cinch and I expect an rsync between them will be nice and fast as well. :D
- SandsharkAug 29, 2020Sensei
It should be re-building the entire volume. Anyway, yes, a factory default was going to be my suggestion if nothing on the drives mattered to you. The drive order likely wasn't the issue. More likely, the OS partition on the drives was damaged in some way.
- SamirDAug 29, 2020Prodigy
From what I could tell in the previous thread, it looks like a log file can get too large and cause problems, but the factory reset did clear it up as it is back to 100% again. I do need to probably scrub test the entire volume before I put anything on it. I've also thought about putting in 4x 16TB exos drives I have just to 'see what this thing can do'. I'm sure the volume won't be able to exceed 16TB, but will it allow me to make multiple volumes?
I was almost certain that drive order matters on these if it is more than a single drive. Is this definitively not the case?
