Davieboy0312
Dec 23, 2022Aspirant
Readynas 2100
Hi there and will apologize if you guys have already started and sorted this issue i bought a ready nas 2100 and shows up in Raidar but not on explorer. In raidar it doesnt show Model number ...
Davieboy0312
after swapping some network cables around i now get
your NETGEAR storage is not accessible from this computer. Check network settings
still showing the same ip address
please help !!!
Dec 23, 2022Guru - Experienced User
Is the SMB 1/CIFS client enabled on the PC (go into "turn windows features on or off" to check.
- Davieboy0312Dec 23, 2022Aspirant
I have done as you suggested
When i click admin page it does nothing BUT when i click browse it take me to explorer
Also says on Raidar "status - corrupt root"
Have none a OS reinstall but doesnt help
I am getting somewhere at last
- StephenBDec 24, 2022Guru - Experienced User
Were the disks you put in the NAS formatted?
Have you tried a factory default?
- Davieboy0312Dec 24, 2022AspirantHi there
Yes I have done a format and an OS install. Still didnt work. Currently running a zero format on both drives. Then do I run an OS install when they are done?
