Davieboy0312
Dec 23, 2022Aspirant
Readynas 2100
Hi there and will apologize if you guys have already started and sorted this issue i bought a ready nas 2100 and shows up in Raidar but not on explorer. In raidar it doesnt show Model number ...
Dec 23, 2022Guru - Experienced User
Davieboy0312 wrote:
your NETGEAR storage is not accessible from this computer. Check network settings
Is the SMB 1/CIFS client enabled on the PC (go into "turn windows features on or off" to check.
Davieboy0312
I have done as you suggested
When i click admin page it does nothing BUT when i click browse it take me to explorer
Also says on Raidar "status - corrupt root"
Have none a OS reinstall but doesnt help
I am getting somewhere at last
- StephenBDec 24, 2022Guru - Experienced User
Were the disks you put in the NAS formatted?
Have you tried a factory default?
- Davieboy0312Dec 24, 2022AspirantHi there
Yes I have done a format and an OS install. Still didnt work. Currently running a zero format on both drives. Then do I run an OS install when they are done?- StephenBDec 24, 2022Guru - Experienced User
Davieboy0312 wrote:
Yes I have done a format and an OS install. Still didnt work. Currently running a zero format on both drives. Then do I run an OS install when they are done?To be clear, you either want to boot with blank/zeroed disks, or you want to do the factory default procedure from the front panel. You don't want to boot with disks formatted on a non-ReadyNAS system. If you did that, you will see a corrupt root error, and an OS-reinstall will not help.
If you install blank or zeroed disks, then the NAS will automatically do a factory install when you power up (and will format the disks). Similarly if you do the factory default procedure from the boot menu, the system will do a factory install. Either way, there is no need to follow up with an OS reinstall.
Rules for disk replacement (hot-swapping) are a bit different. With OS 4.2.x systems (shipped OS on the 2100), hot-inserting a disk will format it and add it to the array. OS-6 changed that policy - an OS-6 system requires that you manually format before it will add an already-formatted disk to the array.
