travishayler
Oct 10, 2019Aspirant
ReadyNas 212 Bonding Accessibility
Morning all, I tried to setup bonding for both NIC's this morning. The NAS was accessible via the browser however the network accessibility stopped working. Remove the bonding and it works again. An...
travishayler
The NAS is actually a 312 and runnign 6.10.1, problem started about 3 weeks ago. They have about 8 PC's running on a standard network with a simple switch. This issue has just started to occur with no major changes in the network at all. No installed apps on the NAS either.
I have since just reverted to using both NIC's one fixed and one DHCP. Not sure if it will help or not if you feel it is memory orientated.
It might be time to migrate to Azure if the NAS is falling over. Really odd that there are no warnings or obvious issues when looking at the logs/performance.
Oct 10, 2019Guru - Experienced User
TLB or ALB aggregation can work with a simple switch, so you could also use one of them. Though perhaps leave it as it is for a couple days, to see if it makes any difference.
Note that 6.10.2 is now released, so you could also update the firmware. https://kb.netgear.com/000061280/ReadyNAS-OS-6-Software-Version-6-10-2
The memory leak is just a guess - it'd more more likely to be the cause if you had apps running.
How about Antivirus and File Indexing? Are they running on the NAS?
You could also download the full log zip, and look in there for issues. One option is to send a downloadable link via private message to one of the mods ( JohnCM_S or Marc_V ) asking them to analyze. Click on the envelope icon in the upper right of the forum page to send a PM. Don't post the link publicly.
