andyhogg19
May 08, 2020Aspirant
ReadyNAS 212 error message on admin page
Hello All, Not stopping me working, but a little annoying. I infrequently visit the Admin page for my ReadyNAS, however when I do, I always get an error message. If I ignore it, then I can use th...
JohnCM_S
May 08, 2020NETGEAR Employee Retired
Hi andyhogg19,
When do you get this error? Is it after you logged in to the admin page or are you getting this intermittently while navigating the admin page?
Are you getting the same issue when using other web browsers?
- AlanPompeyColeJul 14, 2020Aspirant
I have this same issue just started every time after I am ogging into the admin page.
Is it because kit has been installed 12 months?
There are 2 Seagate IronWolf 8 TB NAS Internal Hard Drive HDD installed.
I am ignoring the message so far but what is the cause and can I prevent it showing up.
- StephenBJul 14, 2020Guru - Experienced User
I don't see it, so this is something specific to your setup.
On the PC:
- What browser are you using?
- Do you have internet security software installed, or ad blockers running?
- Is there a proxy installed?
On the NAS:
- What firmware are you running?
- Have you installed an apps on the NAS? If so, which ones?
- Have you redirected default web access in the http settings of the NAS? (system->settings->services->HTTP)
