TXSWoodruff's avatar
TXSWoodruff
401 Authorization Error message
Just installed Orbi RBR40 and 3 satellites. Generally working well but receiving a 401 Authorization error on several devices, Apple iPad and iPhone. Other devices working OK.
Devices working well show Network on the Devices map, others not working well show Smart Phone or iPad.  Interesting but not sure if it’s relevant. RBR40 FW is V2.3.5.30
  • FURRYe38's avatar
    Where are you seeing this Authorization Error message on these devices?
    Try the Forget This Network for all Apple devices. The then power off then back on and re-connect.
    Is the Orbi system operating in Router or AP mode?
    • TXSWoodruff's avatar
      TXSWoodruff
      To answer your questions, we would see the 401 Auth message when clicking on an old, saved link to a website.  Sometimes even typing in the URL in the search line would result in the 401 Auth message.  Same for my husband. But it did not happen with all old links, only some, and it appeared to be random. I did not have as many issues as he did on his devices.
      Also, we are on Excede (ViaSat) satellite internet. The modem is an Excede WiFi Modem. There are no model numbers on it or on the installation manual. We've had this modem for ~4 years. Not thrilled with satellite but its the best we can do in rural America for now. Based on another response, I did do a traceroute command and I think I have a double NAT.
      And the new ORBI router is operating in Router mode, not AP mode. Today is day 3 of our new network. Coverage is outstanding. Weird thing is I now cannot recreate the 401 Auth message on my devices. Yesterday, I did do a complete reboot of everything, even the Excede modem, the ORBI router and reconnected the satellites, then rebooted all our Apple devices.
      When in doubt, reboot.  I will post again if I see the 401 Auth error again. Thank you for your help!
  • Please test for double NAT as follows:
    Please open a Command Prompt on any computer attached to Orbi and type:
    > tracert 8.8.8.8  (or traceroute 8.8.8.8 if you're using a Mac computer)
    1. If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
    2. If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the root cause of the issue,
      TXSWoodruff
      Thank you - yes I do see two private IP addresses when I do a traceroute (I am on a MacBook Pro). First IP address is the ORBI router, followed by the Excede WiFi Modem. Looks like we do have a double NAT.
  • Recently reset my RBR40 back to the factory settings and after that have been getting a lot of 401 unauthorized access errors. This happens even via Chrome or Safari. Orbi router is connected via an AT&T Arris NVG 599. No issues accessing the same sites via the AT&T modum.
    • ekhalil's avatar
      ekhalil
      Master
      This can be a double router issue.
      • brianbarth61's avatar
        brianbarth61
        Below is what I get and it appears ok please let me know.
        Brians-MBP-2:~ brianbarth$ traceroute 8.8.8.8
        traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 52 byte packets
        1  dsldevice (192.168.1.254)  5.226 ms  2.103 ms  1.768 ms
        2  107-216-40-1.lightspeed.austtx.sbcglobal.net (107.216.40.1)  18.895 ms  8.209 ms  3.443 ms
        3  * * *
        4  12.123.240.166 (12.123.240.166)  13.522 ms  18.120 ms  12.485 ms
        5  12.122.85.197 (12.122.85.197)  16.769 ms  10.185 ms  10.027 ms
        6  206.121.120.90 (206.121.120.90)  16.445 ms
            206.121.120.70 (206.121.120.70)  10.369 ms
            206.121.120.90 (206.121.120.90)  9.923 ms
        7  108.170.240.129 (108.170.240.129)  11.426 ms
            108.170.252.129 (108.170.252.129)  11.499 ms *
        8  108.170.226.57 (108.170.226.57)  16.418 ms
            dns.google (8.8.8.8)  13.778 ms  9.983 ms
