Ihshinron
Apr 17, 2025Aspirant
ReadyNas 212 HELP needed
Hello all, I have a Readynas 212 and I need help after making many errors. I currently have 2x 4TB drives. Drive #1 is older and had data already. I turned from JBOD to RAID1 by moving for X-RAID...
- Apr 23, 2025
Ihshinron wrote:
is there anything that can be done to try to recover the data on either 4TB #1 or #2?
First, don't bother with tailed drive. Boot up the system with only the 4 TB drive in place.
If you are still using password as the NAS admin password, then change that to something. Then double-check that ssh is still enabled in system->settings->services->ssh.
You can then download WinSCP ( https://winscp.net/eng/index.php ). That supports a protocol called SFTP. Set up a connection that uses that protocol.
Use the IP address of your Nas (not the one in the screen shot).
After you connect, the right pane should look something like this:
Somewhere in that list you should see your DSK-4TB folder. Navigate into it, and see if your shares are listed. If they are, you can copy them to a disk on the PC.
Apr 18, 2025Guru - Experienced User
Ihshinron wrote:
Should l eliminate/destroy that "data" volume that is showing up there with 0 for Data and 0 for Free Space?
No. Doing that will make it even more difficult to recover.
Ihshinron wrote:
Then saw that Drive #2 is degraded,
Drives are never degraded. Volumes are degraded. Shuffling around drives might have made recovery more difficult.
FWIW, if you were running XRAID before, all you needed to do was hot-insert the new drive.
Ihshinron wrote:
I've downloaded the logs
I can take a look if you like. Upload the full log zip to cloud storage (dropbox, google drive, etc), and send me a PM (private message) with a link. Make sure the permissions are set so anyone with the link can download. You send a PM using the envelope link in the upper right of the forum page.
Don't post the link publicly, there is some privacy leakage when you do that.
Ihshinron
Apr 18, 2025Aspirant
Thank you Stephen, I just snet you a PM with the link.
