Ihshinron's avatar
Ihshinron
ReadyNas 212 HELP needed
Hello all, I have a Readynas 212 and I need help after making many errors.   I currently have 2x 4TB drives. Drive #1 is older and had data already. I turned from JBOD to RAID1 by moving for X-RAID...
  • StephenB's avatar
    Apr 23, 2025
    Ihshinron wrote:
    is there anything that can be done to try to recover the data on either 4TB #1 or #2?
    First, don't bother with tailed drive.  Boot up the system with only the 4 TB drive in place.
    If you are still using password as the NAS admin password, then change that to something.  Then double-check that ssh is still enabled in system->settings->services->ssh.
    You can then download WinSCP ( https://winscp.net/eng/index.php ).  That supports a protocol called SFTP.  Set up a connection that uses that protocol.
    Use the IP address of your Nas (not the one in the screen shot).
    After you connect, the right pane should look something like this:
    Somewhere in that list you should see your DSK-4TB folder.  Navigate into it, and see if your shares are listed.  If they are, you can copy them to a disk on the PC.
ProSupport for Business
